AIR-AP1142N-E-K9 Radio1 shutdown after joined WLC
Dear Sir/Madam,
I am facing an issue that a couple of 1142-N APs cannot up for Radio1 after joined controller (Cisco FlexConn 7500). I am thinking this is set to incorrect country code, but I have no idea of it.
Part Number                          : 73-12836-05
PCA Assembly Number                  : 800-33767-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC163844K9
Top Assembly Part Number             : 800-33775-04
Top Assembly Serial Number           : FGL1641S0S8
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-E-K9
Dot11Radio1                unassigned      NO  unset  administratively down down
Dot11Radio1.1              unassigned      YES unset  administratively down down
How can I make sure the AP is in correct country code? Actually I am located in Hong Kong.
Many thanks.
Best Regards
Matthew
Hall of Fame Super Gold
Hong Kong should be using "-N" regulatory domain.
Wireless LAN Compliance Status
Thank you for your quick reply. Is that possible to find out which location is this AP belong to and add the country code in controller? Because as I saw, we can set the radio channel and freq which can connect. Any suggestion? I want to solve this problem without RMA because there are a few APs got the same issues.
Many thanks.
P.S. Tried Country code "Thailand", but cannot change the country code and show error "Error in setting country code"
You can add "HK" in the country code of the controller, HOWEVER, this is not recommended.
The reason is because if you have two (or more) countries with different regulatory domains, then only the common channels will be enabled.  There are even cases when even one of your radios, like 802.11a, will be disabled.
226
