08-30-2010 06:11 PM - edited 07-03-2021 07:08 PM
I have an AIR
-AP-1252AG-A-K9 AP connected to a WS-C3750-48-PS-S and I am getting an error:
%CDP_PD-2-POWER_LOW: - NON_CISCO-NO_CDP_RECEIVED
What do I need to do to clear this error. The STATUS LED blinks RED.
Solved! Go to Solution.
09-02-2010 05:48 PM
I entered these 2 commands in the AP. I still get this error:
%CDP_PD-2-POWER_LOW: - NON_CISCO-NO_CDP_RECEIVED (0000.0000.0000)
What else can you suggest I try?
Thanks.
09-02-2010 06:08 PM
Can you please do a "sh version"?
What power source is the AP connected to?
09-02-2010 06:27 PM
TOR-AP1#sh ver
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:44 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
TOR-AP1 uptime is 50 minutes
System image file is "flash:/c1250-k9w7-mx.124-21a.JY/c1250-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-AP1252AG-A-K9 (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FTX1209901E
PowerPC 8349 CPU at 533Mhz, revision number 0x0011
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:1A:C0:BA
Part Number : 73-10425-05
PCA Assembly Number : 800-27630-05
PCA Revision Number : A0
PCB Serial Number : FOC12071EBM
Top Assembly Part Number : 800-29039-01
Top Assembly Serial Number : FTX1209901E
Top Revision Number : A0
Product/Model Number : AIR-AP1252AG-A-K9
Configuration register is 0xF
TOR-AP1#
It is connected to a C3750-48PS-S switch with PoE
09-02-2010 06:50 PM
Can you reboot the AP and post the show logs after about 5 minutes (takes time for the radios to come up) as well as "sh ip int brief"?
11-05-2010 10:52 AM
I finally got the IOS loaded. Thanks.
11-07-2010 11:35 PM
Hello.
good news that your problem is sovled.
can you please let us know what did you do in order to solve the problem?
where was the problem?
Thanks.
