AIR-AP1252AG-A-K9 error
I have an AIR
-AP-1252AG-A-K9 AP connected to a WS-C3750-48-PS-S and I am getting an error:
%CDP_PD-2-POWER_LOW:  - NON_CISCO-NO_CDP_RECEIVED
What do I need to do to clear this error. The STATUS LED blinks RED.
10 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: AIR-AP1252AG-A-K9 error
Means one of two things:
1.  Your switch is not providing the right amount of power to the AP.  The 1250 requires a minimum of 15.4w to 19.4w of PoE.
2.  Your APs running an old IOS which require no less than 19.4w of power.
Solution:
1.  Remove one of the two modules would work.
2.  Upgrade to the latest IOS version to enable the 1250 to operate at 15.4 with both radios operational.
Please do not forget to rate useful posts.  Thanks.
Same reason as above.
1.  You are running an old IOS that forces the AP to operate at 15.4w
2.  Your switch is providing 15.4w PoE.
You can also get a PWR-INJ4.
I am running 12.4(10b)JA3. What IOS do you recommend I use?
Minimum requirement is 12.4(10b)JDA3.
So if the switch is providing 15.4w, that is not enough for this AP?
It's not.  The 1250 requires a minimum of 19.5w of power using the old IOS.  The new IOS as previously posted will allow users to use 15.4w and allow use of both radios AT A COST of lower MCS rates.
If the solution provided was successful, please don't forget to mark this topic as "Answered".   Thanks.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Please don't forget to rate our useful posts.  Thanks.
Is there anyway I can recover this?
Yes, please upgrade your IOS to the level I've posted.
But how can I do that in the "rommon" state the AP lookslike it is in? I cannot BOOT flash: and I cannot tftp at all. Any suggestions at this point would be appreciated.
Have you gone through this link I've posted previously?  You have copied the .TAR file into the AP, deleted the .BIN file and rebooted the AP.  Since the AP can't read .TAR file, it went into ROMMON.  The easiest way to fix the issue and get the right IOS into your AP is to follow the link I've posted previously (which I've re-posted again below).
Under the interface on the switch that the AP is connected to, are you sure that CDP is enabled? make sure it is.
if CDP is working fine on the switch, try to issue those two commands on your AP
power inline negotiation injector override
power inline negotiation prestandard source
et me know if this works.
Can you please do a "sh version"?
What power source is the AP connected to?
Can you reboot the AP and post the show logs after about 5 minutes (takes time for the radios to come up) as well as "sh ip int brief"?
Solution:
I will upgrade to the latest IOS. I also saw this error:
%DOT11-4-DIVER_USED: Interface Dot11Radio1, Mcs rates 8-15 disabled due to only one transmit or recieve antenna enabled
Can you tell me what is needed to resolve this error.
I am running 12.4(10b)JA3. What IOS do you recommend I use? So if the switch is providing 15.4w, that is not enough for this AP?
I may have totally reset the AP. This is the stage it is in right now.
ap: set
DEFAULT_ROUTER=10.0.0.1
ENABLE_BREAK=no
IP_ADDR=10.0.0.1
MANUAL_BOOT=no
NETMASK=255.255.255.224
TERMLINES=0
ap: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                tftp[5]: (read-only)
ap: set
ENABLE_BREAK=no
IP_ADDR=10.0.0.1
MANUAL_BOOT=no
TERMLINES=0
ap: dir flash:
Directory of flash:/
2    -rwx  108                      env_vars
3    -rwx  1048                     private-multiple-fs
4    -rwx  5                        private-config
5    -rwx  6440960                  c1250-k9w7-tar.124-21a.JY.tar
25424384 bytes available (6444544 bytes used)
Please help me to recover this AP.
Thanks again,
My problem is I did not order an externL power supply since I intended to use my PoE switch. Is there anyway I can recover this?
Thanks again.
I have recoverd the AP using your recommendations and with an external power adapter. I have upgraded the IOS to the latest version  c1250-k9w7-mx.124-21a.JY . I still get the original error:
%CDP_PD-2-POWER_LOW:  - NON_CISCO-NO_CDP_RECEIVED  (0000.0000.0000)
Any suggestions?
Thanks.
I entered these 2 commands in the AP. I still get this error:
What else can you suggest I try?
Thanks.
TOR-AP1#sh ver
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:44 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
TOR-AP1 uptime is 50 minutes
System image file is "flash:/c1250-k9w7-mx.124-21a.JY/c1250-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-AP1252AG-A-K9    (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FTX1209901E
PowerPC 8349 CPU at 533Mhz, revision number 0x0011
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:1A:C0:BA
Part Number                          : 73-10425-05
PCA Assembly Number                  : 800-27630-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12071EBM
Top Assembly Part Number             : 800-29039-01
Top Assembly Serial Number           : FTX1209901E
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1252AG-A-K9
Configuration register is 0xF
TOR-AP1#
It is connected to a C3750-48PS-S switch with PoE
I finally got the IOS loaded. Thanks.
Hello.
good news that your problem is sovled.
can you please let us know what did you do in order to solve the problem?
where was the problem?
Thanks.
2192
