ā02-24-2014 08:45 AM - edited ā07-05-2021 12:16 AM
Is there any way to set these AP's to factory default settings via the console?
We have a number of AP's controlled by a 520 controller which no longer show.
I would like to start the whole setup process from scratch
Any advice appriciated
ā02-24-2014 10:04 AM
Take a look at this thread as it has instructions on how to factory reset the AP:
https://supportforums.cisco.com/thread/2127213
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
ā02-25-2014 12:11 AM
Many Thanks
I already came across this I'm looking to wipe any configuration on the AP's this was for the controller.
The copntroller has been factory reset as per the instructions in that documnet but it can see the AP's so I wish to rest those also
ā02-25-2014 01:35 AM
Hi Matt,
I assume you have access to the MODE button on the AP.
If so you can use steps.
Step 1 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2 Press and hold the MODE button while you reconnect power to the access point.
Step 3 Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
More details can be found on below link. Even though this document is inteneted for IOS AP's it should work with LightWeight as well.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
