AIR-CAB150ULL-R Cable thickness
Does anyone know where I can find out the diameter of the 150ft ultra low loss cable that Cisco uses to connect external antennas to access points?
thanks
Bruno Wollmann
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: AIR-CAB150ULL-R Cable thickness
Hi Bruno,
The Cisco Ultra Low Loss cable is LMR600. The outside diameter is .59"
Hope this helps!
Rob
Hi Bruno,
Hope this helps!
Rob
This is exactly what I'm looking for. Thanks Rob.
Hi Bruno,
You are most welcome :) Best of luck!
Rob
352
