03-18-2014 08:04 AM - edited 07-05-2021 12:28 AM
Hello all,
I have a problem with a WiSM2 running on 7.4.110.13. It is installed in Russia and we are trying to connect new 1600 APs AIR-CAP1602I-R-K9 for the -R Regulatory. But the AP cannot connect/join to the WLC.
Product Version.................................. 7.4.110.13
Configured Country:
Configured Country............................... RU - Russian Federation
Time is synchronized with an NTP Server and location is set.
No auth-list is configured, and MIC is enabled.
Authorize MIC APs against Auth-list or AAA ...... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
AP with Manufacturing Installed Certificate.... yes
AP with Self-Signed Certificate................ no
AP with Locally Significant Certificate........ no
I have 500 free licenses:
Licensed Feature Max Count Current Count Remaining Count
AP Count 500 0 500
I also did a reset of the AP using the Mode button. But this did not change anything.
If I enable the following debugging "debug capwap error enable" I get the following messages:
*spamApTask2: Mar 18 15:54:47.407: 88:5a:92:58:67:d0 State machine handler: Failed to process msg type = 1 state = 0 from 172.31.140.132:34430
*spamApTask2: Mar 18 15:54:47.407: 88:5a:92:58:67:d0 Failed to parse CAPWAP packet from 172.31.140.132:34430
So the first packet the WLC gets from the AP is immediately dropped.
Any idea?
03-18-2014 08:28 AM
Maybe a "debug capwap payload enable" gives anyone an idea.
*spamApTask1: Mar 18 16:25:19.338: 88:5a:92:c3:f7:c0 Board data options: antType 1, apType 0, joinPriority 1
*spamApTask0: Mar 18 16:25:19.338: Start of Packet
*spamApTask0: Mar 18 16:25:19.338: Ethernet Source MAC (LRAD): 64:AE:0C:41:D2:40
*spamApTask0: Mar 18 16:25:19.338: Msg Type :
*spamApTask0: Mar 18 16:25:19.338: DISCOVERY_REQUEST
*spamApTask0: Mar 18 16:25:19.338: Msg Length : 70
*spamApTask0: Mar 18 16:25:19.338: Msg SeqNum : 0
IE : UNKNOWN IE 58
*spamApTask0: Mar 18 16:25:19.338: IE Length : 1
*spamApTask0: Mar 18 16:25:19.338: Decode routine not available, Printing Hex Dump
*spamApTask0: Mar 18 16:25:19.338: 00000000: 03 .
IE : UNKNOWN IE 50
*spamApTask0: Mar 18 16:25:19.338: IE Length : 46
*spamApTask0: Mar 18 16:25:19.339: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 46 47 4c 31 ............FGL1
00000010: 37 34 35 53 32 41 32 00 00 00 00 00 00 00 00 00 745S2A2.........
00000020: 00 00 00 00 01 01 00 0
IE : RAD_PAYLOAD
*spamApTask0: Mar 18 16:25:19.339: IE Length : 14
*spamApTask0: Mar 18 16:25:19.339: H/W Version : 1
*spamApTask0: Mar 18 16:25:19.339: H/W Release : 0
*spamApTask0: Mar 18 16:25:19.339: H/W Maint : 0
*spamApTask0: Mar 18 16:25:19.339: H/W Build : 0
*spamApTask0: Mar 18 16:25:19.339: S/W Version : 7
*spamApTask0: Mar 18 16:25:19.339: S/W Release : 5
*spamApTask0: Mar 18 16:25:19.339: S/W Maint : 1
*spamApTask0: Mar 18 16:25:19.339: S/W Build : 73
*spamApTask0: Mar 18 16:25:19.339: Boot Version : 15
*spamApTask0: Mar 18 16:25:19.339: Boot Release : 2
*spamApTask0: Mar 18 16:25:19.339: Boot Maint : 2
*spamApTask0: Mar 18 16:25:19.339: Boot Build : 0
*spamApTask0: Mar 18 16:25:19.339: numSlots : 0
*spamApTask0: Mar 18 16:25:19.339: numFilledSlots : 0
disable-all *spamApTask0: Mar 18 16:25:19.339: End of Packet
03-18-2014 08:59 AM
Paste the output of these commands:
From WLC: sh sysinfo
From AP: sh version
also connect console to AP and then reboot it and paste the whole entire boot process here.
Dont forget to rate helpful posts
03-19-2014 06:14 AM
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.43.32
Firmware Version................................. FPGA 1.6, Env 0.0, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... rus-wism-01-3
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1293
Redundancy Mode.................................. Disabled
IP Address....................................... 172.25.16.148
Last Reset....................................... Software reset
System Up Time................................... 5 days 21 hrs 24 mins 2 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 9
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 6C:20:56:2C:5C:E0
Maximum number of APs supported.................. 500
AP885a.9258.67d3#sh vers
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:41 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP885a.9258.67d3 uptime is 22 hours, 25 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-R-K9 (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1745S2AM
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:5A:92:58:67:D3
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC174185AV
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1745S2AM
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-R-K9
Configuration register is 0xF
AP885a.9258.67d3#relo
AP885a.9258.67d3#reload
Proceed with reload? [confirm]
Writing out the event log to flash:/event.log ...
*Mar 1 22:41:20.092: %SYS-5-RELOAD: Reload requested by cisco on console. Reload Reason: Reload Command.
*Mar 1 22:41:20.092: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
*Mar 1 22:41:23.844: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
Boot from flash
IOS Bootloader - Starting system.
FLASH CHIP: Spansion S25FL256
Xmodem file system is available.
flashfs[0]: 10 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 6816768
flashfs[0]: Bytes available: 25119232
flashfs[0]: flashfs fsck took 9 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 88:5a:92:58:67:d3
************* loopback_mode = 0
Loading "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"...#####################
File "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x100000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Initializing flashfs...
flashfs[2]: 10 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31808000
flashfs[2]: Bytes used: 6816768
flashfs[2]: Bytes available: 24991232
flashfs[2]: flashfs fsck took 9 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
no ip http server
% Invalid input detected at '^' marker.
export@cisco.com.
% Please define a domain-name first.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Press RETURN to get started!
*Mar 1 00:00:12.427: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:13.487: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:14.511: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:14.939: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:15.951: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
logging facility kern
logging trap emergencies
*Mar 1 00:00:26.975: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:00:26.975: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar 1 00:00:26.975: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:26.975: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:39.451: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inline power source
*Mar 1 00:01:02.739: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:01:21.739: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:01:39.454: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inline power source
*Mar 1 00:01:40.738: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
03-19-2014 06:45 AM
Ap is not able to find the WLC.
From where AP will get the IP ??
Did you configued any DHCP pool fro APs to get ip ??
Try to create a DHCP pool for AP on layer 3 switch ...example:
keep AP and WLC on same subet :)
ip dhcp excluded-address 172.25.16.1 172.25.16.170
ip dhcp excluded-address 172.25.16.185 172.25.16.254
ip dhcp pool WirelessLAN
network 172.25.16.0 255.255.255.0
default-router 172.25.16.254
option 43 ip 172.25.16.148
lease 3
03-19-2014 06:56 AM
As this is a test AP connected in the HQ, I configured it with an static IP Address and also configured the WLC IP manually.
AP885a.9258.67d3#sh capwap ip config
LWAPP Static IP Configuration
IP Address 172.31.140.132
IP netmask 255.255.255.0
Default Gateway 172.31.140.1
Primary Controller 172.25.16.148
In other places we use DHCP.
But you can be sure that all the APs find the WLC, otherwise I would not see the incomimg DISCOVERY_REQUEST in the debugging. Right?
03-19-2014 08:40 AM
paste the whole console log from AP(reboot it and then paste entire bootup process).
03-19-2014 10:23 AM
You can find it above:
03-19-2014 10:28 AM
Hey ,
can you ping WLC from AP ?
try to create a DHCP pool and remove static entries.
I dont see any join request from client to WLC.
There must be something wrong between WLC and AP.
03-19-2014 10:38 AM
Yes, I can ping the AP from the WLC.
(rus-wism-01-3) >ping 172.31.140.132
Send count=3, Receive count=3 from 172.31.140.132
And when you check my first entry on that discussion you can see that the debugging on the controller logs the following messages:
So the DISCOVERY_REQUEST sent by the AP is received by tye WLC (see also the debug below). Then the WLC logs "Failed to process..." and drops the request.
03-19-2014 10:47 AM
I dont see any reason .....
you can upgrade FUS image on WLC and then try again, may be it helps.
http://software.cisco.com/download/release.html?mdfid=283791169&flowid=24822&softwareid=284364857&release=1.9.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest
If still fails then paste the entire console log from AP(first reboot and then take the log for 5 minutes..)
03-20-2014 01:04 AM
I tested an ETSI AP and it worked.
So I upgraded the FUS and now also R APs can connect.
