AIR-CAP3502E-E-K9
I have a large amount of internal 2602i and external 3502e Access Points at one of my sites,  I have the following Antenna AIR-ANT5160V-R for 5GHz and AIR-ANT5160V-R for 2,4GHz these have one cable per antenna, plugged in as follows 2.4 in port A and 5 also in the repective port A.  The issue I am having is, clients will only connect at a 5GHtz, I have equipment that will only work on b/g, consiquently these fail to connect on the external AP's, as soon as you enter a building, they connect straight away.   I have attached the Radio Templates.  I am running Prime Infrastructure 1.4 and Controller Code 7.5.102.0
HELP!!!!!
nev
Bronze
AIR-CAP3502E-E-K9
you have AIR-ANT5160V-R for both 5Ghz and 2.4Ghz?
here are the supported types for the 3500 http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
also check on the WLC itself if the radios are up for those AP's?
here is a useful guide for the 3500 http://www.cisco.com/en/US/docs/wireless/access_point/3500/quick/guide/ap3500getstart.html
http://www.cisco.com/en/US/docs/wireless/technology/apdeploy/Cisco_Aironet.html
and show tech from the AP
Re: AIR-CAP3502E-E-K9
No I have AIR-ANT24120 for 2.4 and AIR-ANT5160V-R for 5. All radios are on. Looks like we have some signal strength issues externally, but perfectly fine internally.
I have a mixture of 2602i and 3502i internally.
465
