AIR-CAP3602I-N-K9
Hi guys,
We've just purchased 4 of these WAPs and are now getting them set up - first issue we've run in to is it blinks Red / Yellow / Green. They didn't come with a manual, and the documentation on this site doesn't mention the LED being capable of blinking yellow so this has caused a fair amount of confusion. Can anyone shed some light on this?
Thanks.
Hall of Fame Super Gold
The AP you've purchased are
The APs you've purchased are most likely running on controller-based IOS.  If you don't have a wireless LAN controller (WLC) then you'll need to convert the AP to run autonomous IOS.  This can easily be done if you follow this procedure:   Using a TFTP Server to Return to a Previous Release
Thanks for that, Leo.
If you don't mind, I've got
If you don't mind, I've got another question - we actually do have a controller, but are unable to connect to the WAP (it does have an IP and we can ping it) with SSH or Telnet, and sticking it's IP address in the browser doesn't work either. What've I missed?
Post the output to the
Post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
WLC is a Cisco 2921 Router.
sh sysinfo was not recognised as a command.
The only command relating to time was sh time range
We cannot connect to the AP to type in any commands, but those ones did work on the router. (We confirmed with sh inventory that our WLC module was installed)
That means your WLC module is
That means your WLC module is not configured properly.
92
