11-18-2010 04:00 AM - edited 07-03-2021 07:25 PM
I need to connect a WLC AIR-CT5508 with a Catalyst 6500 VSS.
In the WLC Configuration guide, talking about LAG, Cisco says:
"When configuring bundled ports on the controller, you may want to consider terminating on two different modules within a modular switch such as the Catalyst 6500; however, Cisco does not recommend connecting the LAG ports of a 5500 or 4400 series controller to multiple Catalyst 6500 or 3750G switches."
¿Does this statement apply with a VSS?
¿Has anyone ever connected a WLC AIR-CT5508 with LAG to a MEC configured in a VSS? ¿May I do it?
Thank you very much for your help.
Best regards,
Jorge
Solved! Go to Solution.
11-18-2010 05:17 AM
Hi Jorge,
this does not apply to VSS.
The whole point is "if you are doing LAG, you want to terminate the link on something that can reassemble the packets". I.e. a switch with several modules can do a port-channel with ports from different modules.
The same way, a VSS allows to build a port-channel just as if you only had one switch (as far as I know). So that is ok.
It's just wrong to connect the WLC to 2 different switches that can't build a portchannel together.
Hope it clarifies :-)
Nicolas
Don't forget to rate answers that you find useful
11-18-2010 05:17 AM
Hi Jorge,
Nicolas
