Community Member
Air Fortress Gateway and 4402 WLC
All,
I'm in the process of a demo/protoype using the cisco lightweight products (4402 controllers w/ 1240 LAP), and using Air Fortress gateway for Layer 2 authentication...I have 3 lightweight AP's associated with the controller (running in Layer 3 mode is only way to get AP's to talk to controller), but when my test client loaded with Air fortress gateway associates with the cisco AP, it's not able to aquire DHCP address, the Air Fortress gateway does not let any traffic thru...the Air Fortress gateway does allow connections thru to dhcp server if I associate to a Intermic AP, then I'm corporate network with Layer 2 FIPS 140-2 encryption via Air Fortress gateway...any one run into same situation?
Bronze
Re: Air Fortress Gateway and 4402 WLC
This chapter describes how to connect access points to the controller and manage access point settings. This chapter contains these sections:
Lightweight Access Point Overview
Using the DNS for Controller Discovery
Dynamic Frequency Selection
Autonomous Access Points Converted to Lightweight Mode
http://www.cisco.com/en/US/products/ps6366/products_installation_and_configuration_guides_list.html
Community Member
I have a lot of experience installing Air Fortress but I need more info from you. Where does the Air Fortress fit in your configuration?
Is it AF --> Controller ---> AP's
OR
Is it Controller ---> AF ---> AP's?
Community Member
The scenario I have is AF--->Controller---->AP's. We are successfull getting through the AF Gateway (AF7500) when we have the following scenario...
AF7500---->Intermec AP, however once we attempt the AF--->Controller--->AP setup, nothing is getting through the AF.
Cisco suggested our problem was tied to the AF Gateway being confused by having the APs, AP-Mgr., the Management interface, and the WLAN traffic all on one VLAN. Per their suggested we have isolated the WLAN traffic in a separate VLAN, but the Cisco scenario is still not passing through the AF gateway.
Community Member
It sounds like the Controller is confused rather than the AF. Is there any debug that can be run on the Controller to see if the encrypted data is being passed through or discarded?
Dave
Community Member
We have AF install and it is working you must trust the controller on the ACS server and in the AP managment of the AF gateway, mac addresses are required in both the ACS server and the AF gateway.
Community Member
hi,
i am also facing a similar issue, i have a fortress sec?re gateway AF2100 connected on to a vlan 88 on a 6500 switch. of which one of the modules is Wireless services module (2 WLC 4404 integrated on a module) configured in Layer 3 mode. and i have 1242 LWAP APs connected on to the network. the Pcoket PC gets associated to the SSID (which is clubbed to vlan 88) but it is unable to ping the gateways encrypted leg. when i sniffed the packets using ethreal i am able to see that there is exchange of packets between both mac-addresses (mac-add of the pocket PC and that of the encrypted leg). but the Pocket Pc does not get registered and it shows no reply when a ping is initiated to the encrypted leg IP.
i can also see that there is a sudden increase in the number of the packets that are being decrypted by the fortress when a ping is initiated by the pocket PC.
At the same time if we remove the LWAPP technology and use autonomous APs in the same setup it works perfectly fine.
what did you mean in your post about registering it with ACS. are you referring to Cisco Secure Access control server here.
Community Member
I more or less have the same problem. I was able to get autonomous APs to work, but not LWAPP APs. I did not have to enter any AP mac addresses to get Autonomous APs to work, so I don't understand why I would need to add the controller if it is between the AirFortress gateway and the AP on the VLAN being used. The controller mac address would not need to go though the AF gateway unless I want to ping it. Still I am not sure how the controller uses the interface IP on that VLAN. I noticed there is a "fortress passthru" setting on the controller, but enabling it did not help. Let me know if you guys figure out a fix.
Randy
657
