AIR-LAP-1131AG stopt functioning - show no radios
Hi, have two units with same problem. Without a known reason the radios stopt functioning. They are no longer in the sh version. The radio led blinks RED like
_________|--|____|--|_|--|   _ means off   - means on
I tried reset, renew firmware, etc.
Anyone a suggestion besides buying a new one?
Klaas.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1112Q0SF
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1B:53:02:16:5C
Part Number                          : 73-8962-11
PCA Assembly Number                  : 800-24818-10
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1107244S
Top Assembly Part Number             : 800-29144-01
Top Assembly Serial Number           : FCZ1112Q0SF
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Configuration register is 0xF
Re: AIR-LAP-1131AG stopt functioning - show no radios
slide open the ap ... what are the colors of the two lights on the inside when the outter ring blicks red?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Hall of Fame Super Gold
If you don't see the radios in the "sh ip int brief" output then it's RMA-time!
Hi George, thanks for your reply. The inside LEDs are steady green for the ethernet and the right most LED is blinking as mentioned.
Regards, Klaas.
hummmm... attached is a link to the LED status.. nothing matches what you are seeing
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c4.html#wpxref37237
And you tried to down grade to autonomous with no luck ?
HI George,
Yes the unit is in Autonomous mode now. It will do firmware loading and so on.
I have connected a new AP but just was curious if someone has a solution for this.
Anyways, thanks for your help. Regards, Klaas.
bud sounds like its an RMA....
1565
