02-16-2012 09:30 PM - edited 07-03-2021 09:36 PM
I've a 2106 WLC and the software is upgrade to 7.0.220.0. There are 3 APs with external power adapter work normally on it.
Here is the problem:
There is another AP with external power adapter has join the the WLC successfully. But it can not enable the radio 802.11b. Following is the error message on CLI, What could be the reason and solution for it? Thanks a lot!
(Cisco Controller) config>802.11b enable AP001d.a1ef.b5f4
Cisco AP has not enough in-line power to enable radio
02-16-2012 09:33 PM
Go that AP from the WLC
WLC GUI >> WIreless >> AP >> AP Edit >> Advanced >> We see Power inline or power injector..
Please fiddle around this and see if that helps!!
Surendra
02-16-2012 10:28 PM
It is still not work.
Following is my step:
1. I selected "Power Injector State"
2. There is 2 selection for "Power Injector Selection". "installed"and"override". I've tried them both.
Please help~
Thank you!
02-16-2012 10:54 PM
Please post the output to the following command:
WAP:
1. sh version;
2. sh inventory
WLC:
1. sh sysinfo
Next, attach a console cable to the WAP and reboot the WAP. Post the entire bootup process including the JOIN process.
02-16-2012 11:23 PM
WAP
1. sh version
AP001d.a1ef.b5f4#show version
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:07 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
AP001d.a1ef.b5f4 uptime is 43 minutes
System image file is "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-C-K9 (PowerPCElvis) processor (revision A0) with 27638K/5120K bytes of memory.
Processor board ID FOC11520JRM
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.220.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:A1:EF:B5:F4
Part Number : 73-8962-12
PCA Assembly Number : 800-24818-11
PCA Revision Number : B0
PCB Serial Number : FOC11520JRM
Top Assembly Part Number : 800-29144-02
Top Assembly Serial Number : FOC11520JRM
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-C-K9
Configuration register is 0xF
2. sh inventory
AP001d.a1ef.b5f4#show inventory
NAME: "AP1130", DESCR: "Cisco Aironet 1130 Series (IEEE 802.11a/g) Access Point"
PID: AIR-LAP1131AG-C-K9, VID: V04, SN: FOC11520JRM
WLC
1. sh sysinfo
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
RTOS Version..................................... 7.0.220.0
Bootloader Version............................... 4.0.191.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.828
IP Address....................................... 10.51.132.246
System Up Time................................... 0 days 20 hrs 13 mins 55 secs
System Timezone Location.........................
Configured Country............................... CN - China
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +52 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 3
Number of Active Clients......................... 74
Burned-in MAC Address............................ 00:1E:13:50:93:C0
Maximum number of APs supported.................. 6
I'll try to get console log later because I could just access the AP remotly at this moment.
By the way, I've tried to replace this AP with another one which could work normally in another room. It doesn't work as the first one. Is it possibel for the switch's prolbem?
Thanks a looooooooot!
02-16-2012 11:27 PM
Depends. One of the few times I've seen the radios going down is when you combine power injector to, say, a 2940/2950 switch. Not certain until you console and reboot the WAP.
Your output doesn't have anything unusual.
