Community Member
Air-lap1142n-a-k9 Autonomous
Hi I'm having a hard time configuring my AP to Autonomous.  In priviledge mode I try to type configure terminal but this is all I have as an option.
cd  clear  clock  crypto
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx
I tried following the instructions from that post, but I didn't even get the archive command.  I reset the AP but I get the same outcome.  I tried to boot it in Rommon but hitting the break key isn't doing anything.
Can someone please tell me what I'm doing wrong?
Thank you!
Hall of Fame Super Blue
Community Member
Thank you
