AIR-LAP1252AG-T-K9 joins 10M to giga 6509 port
Allthought AIR-LAP1252AG-T-K9 has gigabit 0 configured to  "speed auto" it joins 6509 giga port as Full-duplex, 10Mb/s.
AIR-LAP1252AG-T-K9 configutaion:
#sh run int gigabitEthernet 0
interface GigabitEthernet0
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
 duplex auto
 speed auto
end
#sh interfaces gigabitEthernet 0
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC 8349 Ethernet, address is 588d.095e.6ea2 (bia 588d.095e.6ea2)
  Internet address is 147.65.106.28/24
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Full-duplex, 10Mb/s, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/4482/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 4 packets/sec
  5 minute output rate 52000 bits/sec, 2 packets/sec
     1444763 packets input, 628263327 bytes, 0 no buffer
     Received 103776 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     1422351 packets output, 839918345 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     50970 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
6509 port configuration:
#sh run int g 9/41
Building configuration...
Current configuration : 146 bytes
interface GigabitEthernet9/41
 description AP28-Corredor 403 - cabo direto
 switchport
 switchport access vlan 106
 switchport mode access
end
#sh int g 9/41
GigabitEthernet9/41 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0015.faca.e8c4 (bia 0015.faca.e8c4)
  Description: AP28-Corredor 403 - cabo direto
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:00, output 00:00:19, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 29020
  5 minute output rate 39000 bits/sec, 1 packets/sec
     92109946 packets input, 30219611673 bytes, 0 no buffer
     Received 417088 broadcasts (206667 multicasts)
     0 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored
     218838486 packets output, 146798721996 bytes, 0 underruns
#sh int g 9/41 status
Port         Name               Status       Vlan       Duplex  Speed Type
Gi9/41       AP28-Corredor 403  connected    106        a-full   a-10 10/100/1000BaseT
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Run a TDR test.  Maybe the
Run a TDR test.  Maybe the cable is >100 metres.
1 REPLY
57
