Community Member
Air PCM340 Windows CE 2002 support?
I have a Cisco AIR-PCM340 I'm tring to use with my IPAQ Model 3650. Its running Windows CE 3.0.11171. I have tried both drivers on Cisco's site and it tells me the LAN Adaptor does not support the connected device type. What driver should I use?
1 REPLY
Silver
Re: Air PCM340 Windows CE 2002 support?
A client adapter installed in a Compaq Ipaq eventually loses its ability to communicate with an access point because the MAC address under the NetworkAddress registry entry changes . Modifications to the power-down and power-up routines were made to resolve this caveat in driver release 2.22.
151
