AIR-PCMCIA350
Good evening,
I need a wireless PC card software for my AIR-PCMCIA350. I can't use the Windows XP wireless client because I setup my Wireless AP to use WPA-Personal and XP doesn't support that encryption.
I would like to setup this card on my IBM 560 portable, however, I don't have the software. I did check CISCO downloads but I don't see the wireless PC card client software specific for the PCMCIA350. I only see one for the 340.
Any help or direction is most appreciated.
Deb
Re: AIR-PCMCIA350
Thanks lavramov for your quick response.
I will let you know if it worked.
Deb
Re: AIR-PCMCIA350
Hello lavramov,
I downloaded and ran the 350 PC card series bundled (PCM driver, Firmware 350-PCM and Utility-ACU 5.05.001)
My 350 PC card driver version 8.2.3.0 3/19/2002
My Firmware version is V4.25.30
My ACU Utility is 5.05.00
I also updated my Linksys Wireless WRT54G firmware to v1.02.6
However, when I try to create a profile in ACU Profile Manager it displays Not Associated.
Here are my HOME profile settings:
I checked Include Profile In Auto Profile
I entered my SSID name of my Linksys Router
I took the default CAM and Infrastruture
I took the default Auto Rate Selection
I have checked all Use Short Radio Headers, World Mode and Periodically...
I accepted all the defaults for RF Network
I accepted the defaults for Advanced(Infrastruture)
For Network Security Tab:
I selected Host Based EAP
No WEP
I checked the Alow Association to Mixed Cells
HOWEVER, it doesn't connect. Any help would be much appreciated.
Deb
151
