AIR-SAP2602 speed 802.11n inactive
Hi everyone,
I'd like to know why the acces point is broadcasting in speed "G". I'm not sure about mbssid or not that effect to speed of wireless.
How to configure to able "N"?
IOS version 15.2(2)JA
Everyone's tags (3)
Hall of Fame Super Gold
You need either OPEN authentication or you can use WPA2 AES/PSK.
You also need to enable WMM.
Hi Leo,
I do that but still shows on G
I enable wmm on int dot0 with "dot11 qos mode wmm"
CLI below:
dot11 ssid XXX
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
ssid XXX
antenna gain 0
stbc
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel least-congested 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
station-role root
Hall of Fame Super Silver
Re: AIR-SAP2602 speed 802.11n inactive
You need AES not tkip
-Scott
Hi Scott,
I found the problem from encryption vlan 1 mode ciphers tkip after enter to int dot 0
after enter radio is reset and it appear to "G"
I'm change to use this "encryption vlan 1 mo ciphers aes-ccm" after reset show "G" also
Can you tell me why "G" is show after enter encryption vlan x command?
What shows "G", your client adapter? Is your client adapter 802.11n? What you had initially was wrong. 802.11n standard only supports open or the use if aes when using wpa2. If your using wpa2/aes and your client card supports 802.11n, your device should associate using 802.11n as long as its close enough to modulate properly.
-Scott
My notebook, when move the pointer on SSID show "G".
But if remove encryption vlan x "N" is up.
Now, I found in release note that 802.11n HT rate apply only to No Encryption.
It cleared
633
