07-11-2013 08:23 PM - edited 07-04-2021 12:24 AM
Dear all,
i 'm wondering whether the AIR-SSB350-E-K9 is replaceable with AIR-3602-E-K9?
currently the 2 AIR-SSB350-E-K9 are used for outdoor bridge purpose so it is working with cisco Aironet 13.5-dBi Yagi Mast Mount Antenna (AIR-ANT1949), appreicate your help. thanks
07-11-2013 08:35 PM
If your looking at a bridge replacement using the same antenna, your better off using a 1242. It's a waste of money to use a 3602, 2602 or any other model if you ask me. If your looking for a true bridge, then look at the Exalt r5005 which Cisco resells.
07-11-2013 08:42 PM
thanks for your reply, the issue here is sales already ordered the 3602-E , currently cisco Aironet 13.5-dBi Yagi Mast Mount Antenna (AIR-ANT1949) has only 2 interfaces connector but 3602E has 4 interfaces not sure whether it is compatiable with each other?
07-12-2013 05:43 AM
Well you can use it, you just have to disable the other three ports and set which port is your primary TX and RX. Also you will have to convert those access point to autonomous as most likely they are lightweight. To convert, here are some links
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
07-15-2013 10:14 PM
Scott thanks for the tips will work on it.
07-16-2013 04:21 AM
No problem
