Airespace 4100 Series - Web Auth timeout
For a SSID with Web Auth. only, is there a place to extend the timeout feature so the user does not have to repeatedly login???
Silver
Re: Airespace 4100 Series - Web Auth timeout
Use the Session Timeout field under the WLAN properties. I set it for 28800 = 8 Hours. Use newer code as it seems like I have seen a bug on the timer and WebAuth at some point.
Thanks, I will give it a try...
175
