Community Member
Airmagnet Surveyor Active Survey
Hi Team, i had a problem with the active (associated) survey in a WLC Deployment. The Airmagnet did not Roam from one AP to another. Has anybody seen this Problem and possibly an Solution? Regards, Michael
1 REPLY
Community Member
Re: Airmagnet Surveyor Active Survey
I assume you are doing an active survey and associating with a particular SSID. AirMagnet won't roam from one AP to another until the signal strength drops to a very low level. If you want to associate with a particluar AP, then click on the drop down box below the Active radio button and select AP. Then go the the drop down list below the Passive radio button and select the AP you want to survey.
Version 4 does have a roaming option but you have to set criteria for when you want to flip from one AP to the next and this gets a little complicated until you have used it a lot.
338
