05-20-2008 07:08 AM - edited 07-03-2021 03:54 PM
how do i use an existing catalyst 3750 switch as WLC for Aironet 1020 ( I know i need Catalyst 3750 Integrated WLC)
walter
05-20-2008 07:25 AM
Walter,
It's not a module that you just plug in - it's a whole new switch with the combined WLC in the chassis. If you are looking for a module and you have a spare ISR or 2800/3800 router sitting around doing nothing! then the WLCM is a module that you can just plug in!
HTH.
05-20-2008 08:21 AM
i have a 2811 on the same site. which module do i need?
walter
05-20-2008 08:24 AM
You need to check it the module will work in that model, but you have two choices:-
1) WLCM - manages 6 AP's
2) WLCM-E - manages 8 or 12 AP's
HTH.
05-20-2008 08:42 AM
thanks.
walter
05-21-2008 12:56 AM
no prroblem - glad to help.
