Community Member
Aironet 1020
how do i use an existing catalyst 3750 switch as WLC for Aironet 1020 ( I know i need Catalyst 3750 Integrated WLC)
walter
Re: Aironet 1020
Walter,
It's not a module that you just plug in - it's a whole new switch with the combined WLC in the chassis. If you are looking for a module and you have a spare ISR or 2800/3800 router sitting around doing nothing! then the WLCM is a module that you can just plug in!
HTH.
Community Member
Re: Aironet 1020
i have a 2811 on the same site. which module do i need?
walter
Re: Aironet 1020
You need to check it the module will work in that model, but you have two choices:-
1) WLCM - manages 6 AP's
2) WLCM-E - manages 8 or 12 AP's
HTH.
Community Member
Re: Aironet 1020
thanks.
walter
Re: Aironet 1020
no prroblem - glad to help.
163
