Community Member
Aironet 1100 - Backing up and Restoring Setup & Config
can one explain the easiest way to back-up and restore the setup configuration of an Aironet 1100 AP? Can this not be done through the web inteface like other manufacturers? can this only be done through a Hyper terminal session? Any help would be greatly appreciated. Thanks.
1 REPLY
Community Member
Re: Aironet 1100 - Backing up and Restoring Setup & Config
Setup the Encryption Manager
Enable Cipher for TKIP.
Clear the value in Key 1.
Set Encryption Key 2 as the Transmit Key.
Click the Apply-Radio# button.
Setup the SSID Manager
Select the desired SSID from Current SSID List.
Choose an appropriate authentication method, by which type of client cards used. If EAP worked prior to the addition of WPA, you should not require change.
Enable key management. First choose Mandatory from the pulldown box, then check the box to choose WPA.
Click Apply-Radio
345
