AirOnet 1100 + DHCP
I've problem with transmition dhcp request from mobile clients to DHCP server.
AirOnet obtain ip address from DHCP, but clients can't obtain the addresses.
I configured AirOnet in agreement with instruction but steel is problem.
Configuration:
version 12.2
no service pad
service password-encryption
hostname #########
ip subnet-zero
ip dhcp smart-relay
ip dhcp relay information option
ip dhcp relay information trust-all
ip dhcp-server 10.0.30.11
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 association mac-list 700
dot11 network-map
dot11 arp-cache optional
bridge irb
interface Dot11Radio0
no ip address
ip dhcp relay information trusted
no ip route-cache
encryption key 1 size 128bit 7 ############################### transmit-key - tu jest prawidlowy
encryption mode ciphers wep128
ssid ####### - tu jest SSID
authentication open
guest-mode
infrastructure-ssid optional
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts threshold 2312
station-role root
l2-filter bridge-group-acl
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
ip helper-address 10.0.30.11
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
/ivory/1100
ip http authentication aaa
ip radius source-interface BVI1
access-list 700 permit ####.####.#### 0000.0000.0000
access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
snmp-server view dot11view ieee802dot11 included
snmp-server community ############ RO
snmp-server chassis-id ############
snmp-server enable traps tty
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 5 15
end
Thx
Re: AirOnet 1100 + DHCP
I would prefer not to use a DHCP address for your AP,.If the ip address changes, you wont be easily able to connect to the Ap for management.
have you made sure, if the clients are configured with correct wep key and ssid ?
Also remove the mac-access-list 700 and see if clients are getting connected.
I would also recommend removing the mac access-list. To test as well, for management purposes you could also apply a static to the bvi interface. Make sure as well that you are not running vlan's on your switch, if you are and your not tagging to a vlan specific vlan you will have connectivity issues. I have noticed some issues with dhcp when operating in this manner. This is of course assuming you are not running in the default vlan of 1 on your switch.
349
