Aironet 1130 - 12.4(3g)JA1
Hi !
I have a strange problem after upgrading from 12.3.11.JA1 to 12.4(3g)JA1 :
interface Dot11Radio0
channel 2437
When I write and reload the ap, then
the channel I configure is gone and the ap doesn't choose the correct frequency.
Anybody else also seen this problem ?
Re: Aironet 1130 - 12.4(3g)JA1
Hi !
I have found the solution to this odd problem :
channel 2437
station-role root fallback shutdown
If change my configuration to :
channel 2437
station-role root
There must be a bug with this fallback configuration.
Hi!
I have the same annoying problem with 1242 Accesspoints. The channel configurations simply disappears from the configuration after an reload ?!
Furthermore I had the station-role root fallback shutdown command set, changed it to station-role root, as you suggested, but no success
has to be bug
regards
CS
Try to use the command "station-role root access-point"
Thanks, that solved the problem ! BUT
I really want the radio to shutdown if FA0 goes down. I find it kind of weird, that any fallback command brings up the channel frequency problem again.
mit freundlichen Gruessen
CS
188
