Community Member
Aironet 1200 Application System Design
I am planning to install the Aironet 1200 series product in my office. I need to determine how to size my system. What is the number of PC's supported by each AP? I will be running 802.11a.
1 REPLY
Re: Aironet 1200 Application System Design
The number of clients supported is much higher than the practical limit.
The design guide recommends 20 to 25 max for standard "laptop" type devices and average network utilization
If you have high bandwidth applications then reduce this number.
With 802.11a you have higher bandwidth so you could have a few more users but in my opinion this defeats the purpose of going 802.11a
If you have a high level of interfrence then this will dramiticaly reduce the amount of bandwidth so I strongly recommend that you do a full site survey before deploying the network
123
