Aironet 1200 Telnet Issue
I have a Aironet that was on a 2651 router with DCHP enabled. We have swapped providers and to a router with no DCHP. Now i cannot assign the aironet an Ip address or change the gateway. I am trying to telnet in but am only getting to an (ap> Prompt). i am doing this by tryuing to access thru the console
I see no way to config it. I am able to connect to the wireless but I have to manually assign an IP on my PC. My customers will need to be able get to it without this issue.
Any help would be appreciated
  • Other Wireless - Mobility Subjects
1 ACCEPTED SOLUTION
Re: Aironet 1200 Telnet Issue
Hello.
Ok if you at the 'ap>' prompt you will need to get into enable mode before configuration the ip address on the bvi interface.
So the cli commands would be:
ap>
ap>enable
password:
Enter your password. Default username and password are 'Cisco'
ap# config t
ap(config)# interface bvi1
ap(Config-if)# Ip address
ap(Config-if)#end
ap#
Hope this helps.
Aaron
Hello.
ap>
ap>enable
password:
ap# config t
ap(Config-if)#end
ap#
Hope this helps.
Aaron
thanks for the reply aalinn
That solved the issue and i am able to access the web interface now.
Thanks again!
232
