aironet 1200 upgrade to latest IOS software failed
when I applied the upgrade through the web intreface and rebooted, the three lights are always on indicated a continuous boot, when I connect thru the console port I see only only very primitive commands such as c copy file, l load file, s system status etc, I do not obatin the ap> command prompt and I cannot locate any references to these console commands on cisco's site, any suggestions or pointers on where to look? TIA
1 REPLY
Re: aironet 1200 upgrade to latest IOS software failed
your IOS upgrade failed and you are in a basic, minimal IOS CLI. To get out of there, you need to download an IOS image to your AP, and to do that you have to do a basic configuration:
> set IP_ADDR=xxx.xxx.xxx.xxx
> set NETMASK=yyy.yyy.yyy.yyy
> set DEFAULT_ROUTER=zzz.zzz.zzz.zzz
> tftp_init
> tar -xtract tftp://YOUR_TFTP_IP/YOUR_IOS_FILE_NAME flash:
> set BOOT flash:/YOUR_IOS_FILE_NAME
> boot
this should do the trick. If you want to check your current values, just enter the "set" command alone.
Hope this helps.
PLS rate all posts
Antoine
225
