Community Member
Aironet 1240AG unable to connect to 802.11b cards
I have numerous 802.11b cards that will not see the wireless network but 802.11g see it fine. I have set it up per the directions to make the 1.0, 2.0, 5.5, and 11.0 as the basic rate. What else do I need to do? Thank you for your help.
Silver
Re: Aironet 1240AG unable to connect to 802.11b cards
That should be all you need to do. Also, make sure you're not using WPA with AES for encryption, as most b-cards won't support this.
At this point you need to isolate whether it's a problem with the access point or a problem with the cards. See if you can find another access point or wireless router, and see if the b-cards can connect.
If you can post your configuration, that would probably help us troubleshoot.
Community Member
I am not useing WPA. The cards can access other access points. Here is my config file and thank you for all of your help:
version 12.4
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname GCPD
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid gcpd
authentication open
guest-mode
dot11 network-map
power inline negotiation prestandard source
username admin privilege 15 password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid gcpd
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid gcpd
dfs band 3 block
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.208.xx.xx 255.255.255.0
no ip route-cache
ip default-gateway 10.208.xx.xx
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
nas 10.208.48.252 key xxx
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Silver
Try the following in config mode:
dot0
channel 1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
See if that works. For some reason this configuration is missing under dot11Radio0. Feel free to use a channel other than 1 if desired.
Community Member
I am sorry to ask this but I am a point and click guy. To perform what you want me to do I will need to log into the device through a Telnet session right? Then once logged in I type config and then start typing one line at a time and enter after each one? Sorry for the neophyte questions but I am not a strong Cisco guy.
Community Member
It might be that Your old cards dont support short preamble.
Try disabling short preamble for the 802.11b radio from the GUI or from the CLI:
Step 1
configure terminal
Step 2
interface dot11radio 0
Step 3
no preamble-short
Step 4
end
Step 5
copy running-config startup-config
Short preambles are enabled by default.
Community Member
Thank you. I will try that and post my results.
Silver
Sorry for not responding for several days, I somehow missed that you had responded. Disabling short preamble is a good idea as well.
When you log in, you actually type "config t", t being short for terminal. Let me know how it goes!
Community Member
No problem at all. I tried what sanamon suggested but it did not work. When trying to type the first line of yours I would get an error after the dot0. The error is invalad entry pointed at the 0. Below is my config file now. Thank you for your help.
version 12.4
no service pad
hostname GCPD
aaa new-model
dot11 ssid gcpd
authentication open
guest-mode
dot11 network-map
username admin privilege 15 password 7 0114050D4B1C0701
bridge irb
no ip address
no ip route-cache
encryption key 1 size 128bit 7 BC29783FA0A56C1897485E061D68 transmit-key
ssid gcpd
no preamble-short
station-role root
bridge-group 1
no ip address
no ip route-cache
encryption key 1 size 128bit 7 426FE03F299DB148A7254A7F123C transmit-key
ssid gcpd
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
radius-server local
nas 10.208.xx.xx key 7 08264F5E0D
bridge 1 route ip
line con 0
line vty 0 4
end
Silver
That's totally my fault. The command line should read "int dot0". I must have been sleepy when writing that out :D
Community Member
I input the info as you suggested unfortunatly it still does not work. I will paste my config agian but I do not see you had me configure. Do I need to do something to save the config? Thank you so much for your help.
version 12.4
no service pad
hostname GCPD
aaa new-model
dot11 ssid gcpd
authentication open
guest-mode
dot11 network-map
bridge irb
no ip address
no ip route-cache
ssid gcpd
no preamble-short
station-role root
bridge-group 1
no ip address
no ip route-cache
ssid gcpd
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
radius-server local
bridge 1 route ip
line con 0
line vty 0 4
end
Community Member
Are You sure the old cards support 128bit WEP? Some cards only supported 48/64 Bit WEP (such as the Orinoco silver cards etc)
From the config I can see that long preambles are now configured.
Community Member
Yes. They were connected to an Aironet 1200 series with 128bit WEP before it died. I really apperciate your help.
Hall of Fame Super Silver
Are your clients configured with the wep key on index 1 and not on 2,3, or 4? So even with an ssid that has no encryption at all, your clients still can't connect?
-Scott
Community Member
That was a good question and yes they are configured on index 1. I am just going to get the users new wireless cards. I have already put more time in this than the cost of the new cards. Thank everyone for all of your help. How do I need to close this thread.
You don't need to close this thread... it will eventually work its way down the page :)
-Scott
Community Member
In that case you might want to turn short preamble back on again as this increases throughput...
Jonas
274
