Community Member
Aironet 1250 doesnt support Block Ack frames
I am using this AP and it looks like this AP doesnt support transmitting BA Frames (I see in the capability info element that "delayed BA" = 0, "immediate BA" = 0.
is it possible to upgrade or to configure this?
thanks
Shaul B.
Silver
Re: Aironet 1250 doesnt support Block Ack frames
1250 series access points supports Block acknowledgement. Refer to the datasheet http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c5c.html for more information.
Community Member
I read in the data sheets that Block Ack is supported. BUT - inside the "capability info element" , the following bits are off : "immediate BA" + "Delayed BA"
do you know if some configuration is need to enable these bits ?
thanks
Shaul B.
204
