Aironet 1310 - not able to establish UDP vpn
We hv installed aironet 1310 in AP as well as root and non root bridge combination with IOS 12.4(3g)JA1.
config works fine for the normal operation like getting client connected to ap, getting IP from DHCP server on the network. The problem is with the UDP vpn. We hv an application which after getting DHCP ip establish the UDP vpn connection which always fails. Aironet 1310 is connected cisco switches.
At some of the AP/bridge playing with the cisco switch setting (speed and duplex) it do work. But that is only a try and error method. But with few other root bridge even trying the same combination doens't work.
Has anyone experience such issue ? Is there any config changes to be made for such UDP vpn ?
Early help would be appreciated.
120
