Till the Non-Root associates with the Root, the Radios will be in Disabled or the Reset state. I guess they are not facing each other or may be some allignment issues, or the authentication no same.. make sure the config on bot hRoot and the Non-Root is exactly same except the ip address and the radio station roles..
If you log into the telnet or the ssh into the Bridge, what is the reason which pops up on the CLI??
Surendra
Surendra BG
