Aironet 1550 Antenna Options
as per reading documentation, i only see the dual-band antenna option for this device. i am planning to use this for multi-site bridging. can i substitute the dual-band antenna with a single-band high gain antenna for such deployment?
Everyone's tags (3)
Hall of Fame Super Gold
No you can't.
Substitute should be able to support dual-band radio.
I heard there is a plan to fix this issue next year ... Little bird told me ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
504
