Aironet 350 client Site browsing?
Hello all. I am in the process of testing/evaluating wireless NICs for my network and have not been able to find a "Site Browse" util in the Cisco ACU. All the other cards I haqve tested seem to have the ability to browse and display all available wireless networks in the air. At which point you can usually select one and connect to it and/or create a permanent profile for it. How can you do this w/ the ACU? It's not a big deal for our network as I will not be broadcasting the SSID's anyway, but my users travel a lot and are always on Hotspots or wireless networks in hotels and such and I would imagine not being able to just see the network(s) in the air might be a bit of an inconvenience.
TIA
Rich Perez
Anonymous
N/A
Re: Aironet 350 client Site browsing?
I don't think this feature is supported currently in Cisco ACU.
jsk
You can always download the free Boingo wireless client software and install it on the client pc.
This application will show you every WLAN it detects with SSID, signal strength, WEP enabled/disabled etc etc.
111
