Aironet 350 Failure after IOS conversion - No FPGA file!
I used the browser to perform the full upgrade to IOS using this image "AP350-Cisco-IOS-Upgrade-Image-v2.img".
After a couple of minutes, the browser return a message indicating the upgrade was complete and instructing me to click on a link to go back the setup page. I clicked on the link but nothing happened. I ended up rebooting the AP.
The following is what I see after reboot. Please help.
Testing DRAM...
(press <esc> to bypass)
DRAM OK
Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc.
Copyright 1984-2000 Wind River Systems, Inc.
System ID: 4326965752A6
Motherboard: MPC855 50MHz, 8192KB FLASH, 16384KB DRAM, Revision B0
Bootstrap Ver. 1.09: FLASH, CRC 710B6415 (OK)
Initialization: OK
Memory Bank total used left
DRAM 16738168 0 16738168
Config 524288 540 523748
FLASH 7733248 0 7733248
Memory Bank:File address size encoding type flags
a) Config:AP Installation Key xxx none Key 0000
b) Config:VAR Installation Key xxx none Key 0000
c) Config:AWC_ConfigDB xxx AiroDB1 Data 0000
Socket Controller Error: No FPGA file!
System ID: 00409dsesdfe
Initialization: Improper Motherboard Config
Type '=' for main menu.
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
  • Other Wireless - Mobility Subjects
1 REPLY
Bronze
Re: Aironet 350 Failure after IOS conversion - No FPGA file!
212
