Community Member
aironet 350 + PBG4
in first i do my appologie for my basic and simplist english.
i have juste one little prob with my power book G4 whit 256 Mo RAm. i install the client utility for aironet 350 - that is ok- reboot - so when i want conf connection. it's very long and the system stop the application when he call the wep key.
I think, i need more ram..
or ???
can you help me?
1 REPLY
Bronze
Re: aironet 350 + PBG4
RAM may not be the issue here. If I understand your question correctly, it takes a long time for you to get connected the applications. Is that correct? If yes, I have a couple of questions for you. After getting connected, is the connectivity stable? Does this happen throughout the day or during specific timings?
123
