Aironet 350BR failed VxWorks to IOS conversion
I have tried to upgrade VxWorks to IOS and by mistake uploaded AP-Upgrade-Image. After restart it gives me the following:
Cisco IOS automatic field upgrade image, ESC to terminate
..10....9....8....7....6....5....4....3....2....1..
upgrade: Compare ok first load file 0
upgrade: Compare ok first load file 1
upgrade: Compare ok first load file 3
upgrade: IOS Configuration component not available
upgrade: Invalid or missing installation key (BR350 not supported)!
Depress ESC key to reboot
Now BR350 has the following files:
Memory Bank total used left
DRAM 16738168 0 16738168
Config 524288 628 523660
FLASH 7733248 4291344 3441904
Memory Bank:File address size encoding type flags
a) Config:BR Installation Key FE020000 64 none Key 0000
b) Config:VAR Installation Key FE020040 52 none Key 0000
c) Config:AWC_ConfigDB FE020074 512 AiroDB1 Data 0000
d) FLASH :IOS_Upgrade 1.0 FE0A0000 393268 none Exec 0801
e) FLASH :IOS_C350_BOOT 2 FE100034 393256 none 0x09 0800
f) FLASH :IOS_C350_TAR 2 FE16005C 3467304 none 0x0A 0800
g) FLASH :IOS_Upgrade_Envs 1.0 FE4AE884 136 none 0x0C 0800
h) FLASH :AWC PCMCIA FPGA 0.14 FE4AE90C 37380 none FPGA 0000
When I press Ctrl+W I have the following options:
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
I can't copy to Flash. When I copy to DRAM Vxworks image file and try to run
Any chance to fix it?
1 REPLY
Re: Aironet 350BR failed VxWorks to IOS conversion
When I copy to DRAM Vxworks image file and try to run it gives me error on decompressing image.
How can I manualy decompress .img file?
216
