Aironet AP1142 Dot11Radio0 inteface reset
Andrey Padiy
We have 4x AP1142 standalone APs in WDS mode with roaming and RADIUS from Windows AD for auth.
Everything works as expected apart from two APs that frequently reset Dot11Radio0 interface. The other two are fine.
The config on all APs is identical, version of IOS is the same accross all APs (12.4(23c)JA3).
The only way to get reset inteface back up is to "reload".
Reset code is :
"show controllers Dot11Radio 0"
Last radio reset code: 06
Radio resets - total:31 retries:0 failed:0
   Code/Count: 06/00031
Log Buffer:
All APs have this enabled :
power inline negotiation injector XX.XX.XX.XX
Here is th eoutput of the logs from the AP where the interface gets reset :
*May  8 18:44:01.576: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4cb1.99ad.d40c Reason: Sending station has left the BSS
*May  8 18:44:29.915: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   00f4.b9c8.c580 Associated KEY_MGMT[WPAv2 PSK]
*May  8 18:44:52.553: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   cc08.e066.9022 Associated KEY_MGMT[WPAv2]
*May  8 18:44:58.513: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 00f4.b9c8.c580 Reason: Sending station has left the BSS
*May  8 18:45:14.645: %DOT11-6-ROAMED: Station cc08.e066.9022 Roamed to f4ea.67be.8350
*May  8 18:45:14.645: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station cc08.e066.9022
*May  8 18:45:16.114: %DOT11-6-ROAMED: Station 5c0a.5b79.7f8b Roamed to f4ea.67c0.07e0
*May  8 18:45:16.115: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 5c0a.5b79.7f8b
*May  8 18:46:11.347: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May  8 18:46:12.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May  8 20:53:18.587: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 10.10.1.12] [localport: 22] at 20:53:18 UTC Wed May 8 2002
Any help appreciated.
14 Replies 14
Amjad Abdullah
Hi Andrey,
Yu have all APs in same physical location? Such issues can be due high noisr/interference or due high number of clients connecting to the AP.
How many clients are connecting to the AP when the issue happens?
Rating useful replies is more useful than saying "Thank you"
4 points spread across two floors in the same building. The problematic APs are on different floors.
In terms of clients, we dont get many, around 10-15 on each AP for both SSIDs. But there are many other 3rd party APs in the area.
Could interference from 3rd party APs cause this?
Yes. Interference around has an effect. This in not the first time i see this behavior with standalone APs. Although it should not behave like this. I remember i was working on a TAC case with same issue and the TAC engineer confirmed it is due interference around. I am not convinced though that the AP should move to radio reset even with high interference.
You can test exchanging one good AP with one problematic AP to verify further.
Are you still connected to the same switch with the MAC address?
I doubt if this is the cause because both radios would be in "reset" if the MAC address doesn't match.
I don't believe that's an IOS version.  I believe it's a Bootstrap version.  What IOS version are you running exactly?
Appologies, copied wrong line
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Across all devices.
APs are connected to different switches if that's what you are asking.
We only have Dot11Radio0 enabled, Dot11Radio1 is manually turned off.
Turn it on.  If Dot11Radio1 goes into "reset" then the MAC address specified for the injector could be the culprit.
Will try, thanks. Although the MAC address was auto detected after running the followig command :
power inline negotiation injector installed
Turning on Dot11Radio1 didn't help and Dot11Radio0 went into reset mode again. Will try swapping APs to see if it's location specific.
Another thing, console into the WAP and reboot the WAP.
Post the entire bootup process.
Do you use hot-standby feature? I think there is a setting that when the radio loses ethernet connectivity it turns the radio down to prevent acting as a repeater.Check for errors in switchports!
And was the problem location specific or RF related or was there something wrong with the AP's ?
For me also:
Well.. replaced both the AP and power injector but still the 2.4Ghz Radio goes into reset after a while.
So i guess this is RF related...
Dont really want to create a TAC case just to see what the reason code 06 means.
Software upgrade to c1140-k9w7-mx.124-25d.JA2/c1140-k9w7-mx.124-25d.JA2 seems to have solved the issue(old version c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1)
Abha Jha
seems to be a power issue or the software issue on AP.
