Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Aironet client - Problem with LEAP and PGP whole disk encryption
Implementing PGP whole disk encryption of laptops with Aironet CB21AG nics and LEAP configuration. Configured to pass login (AD) credentials from PGP login thru to Windows.
Will not pass thru AD credentials at login until LEAP config removed.
Has anyone seen this issue?
1 REPLY
Bronze
Re: Aironet client - Problem with LEAP and PGP whole disk encryp
Check for the LEAP profile configured for the username password and other parameters as an error in configuration might result in the issue you are facing.It will be easier to troubleshoot the issue if the error message you obtain during the process is provided.Check the Error messages present in the troubleshooting guide present in the following url so that you will be able to find the error related to LEAP with the solution for the same:
http://www.cisco.com/en/US/docs/wireless/wlan_adapter/cb21ag/user/4.0/configuration/guide/winc10kh.html
125
