Aironet PCI card
Isn't it the standard PCMCIA card in a PCI adaptor? Wouldn't it work if we used some other PCI adpator?
Re: Aironet PCI card
I had the same thought too. But i checked with Cisco and they told me they did something to the PCI adaptor, so it may not work with another PCI adaptor.
But you can use a PCMCIA card adaptor/reader and use the PCMCIA card in it and get it to work. I know as I am using this setup.
Ron
Ron,
Thanks for the reply!! So if I understand it correctly:
You have Cisco PCMCIA card and a third party PCI adaptor card.
I see the benefit of this would be, that PCI adaptors are fairly cheap out there and can be used with the Cisco Aironet PCMCIA card which has higher gain and security than other 802.11b offerings out there.
Arun Sondhi
CTO,
Network Innovations Inc
715 858 7426 (O)
Its not a PCI adaptor card I am talking about. Its a PCMCIA reader/writer. Just make sure this reader can handle more than just Memory cards. An example will be the SwapBox from Microtech. More info here http://www.microtechint.com/qs-pcireader.html
With the setup, i can use my PCMCIA card on my desktop or notebook when I need to. I only have to get one kind of wireless card and use it on both systems.
Ron
Ron,
I followed the link you provided, seems ideal. What is the price of these? It should be less than $70.00 for it to make sense though.
What does Havenedge Networks PTE LTD do? Just curious?
Arun Sondhi
Dstore sells it for $83.99. there could be other places that sells it for cheaper.
My company does network integration for our clients. Things like router, switches and firewall config. We are located in Singapore.
Ron
318
