Aironet snmp OID to do firmware upgrade
We have several aironet devices. We are an ISP, and we don't have wireless solution engine, but we have to upgrade firmware in several device:Bridges,acces points, workgroup bridges. I read an snmp OID which I can tell the device to upgrade firmware. Only I have to set the default file server, and maybe the default image name in the aironet devices. I can ' t find this document. Is there anybody help me?
Thanks in advance
  • Other Wireless - Mobility Subjects
Bronze
Re: Aironet snmp OID to do firmware upgrade
Here is a URL that has pretty much all the useful information that you need for the Aironet devices. http://www.cisco.com/univercd/cc/td/doc/product/wireless/index.htm
hello
" I read an snmp OID which I can tell the device to upgrade firmware. "
could you share the SNMP OID. I tried browing the MIB and I could not find the value.
I would set the ip addr of the TFTP server and the file name in the config file of the APs and just use the snmp oid to trigger them to upgrade
Hello !
MIB: awcVx
To load firmware from file server:
OID: awcFileXferCmdInvokeFileLoad value: 'start'
status for load:
OID: awcFileXferCmdStatusFileLoad
value:
0 = Operation completed successfully
(or has not taken place).
2 = At least one file was not found on
the file server.
12 = Insufficient memory to load all
files.
22 = No file specified, or invalid file
format.
35 = File format of at least one of the
files is not supported.
68 = Operation is still in progress.
Poll again later.
72 = Operation was started, but later was
canceled."
To save firmware to file server:
OID: awcFileXferCmdInvokeFileSave value: 'start'
status for save:
OID: awcFileXferCmdStatusFileSave
value:
0 = Operation completed successfully (or
1 = Insufficient permission to save the
files.
2 = A directory specified for saving at
least one of the files was not found.
format.
Poll again later.
canceled."
I think it helps you. I tried these with AP1200 and it works!
Hello SZILARD,
Thank you for the reply. After you have sent me the above OIDs, I have tired to work with it. I am using ucd-snmp package. As a test I trried to up load the current image to the tftp server on a AP1200. I used the following command
snmpset 192.168.0.10 -c private awcFileXferCmdInvokeFileSave value: 'start'
The above command gives a error. Please suggest how should I use it ?
I am mainly interested in the procedure to load firmware in APs.
How do I specify the image file ?
Thank you.
what is the error ?
When I use the following command
\usr\bin>snmpset 192.168.0.10 -c private awcFileXferCmdInvokeFileSave value: 'start'
The error that shows up is
'start': Needs type and value
I have downloaded the MIB file from cisco and copied it to the main mib location used by ucd-snmp package.
Hi !
The syntax is :
snmpset ipaddr community snmp-object type value
for example:
snmpset 172.16.11.2 public .1.3.6.1.4.1.522.3.4.7.0 i 2
snmp-object: awcFileXferCmdInvokeFileSave (OID: 1.3.6.1.4.1.522.3.4.7)
i: integer type
integer type 2 =start
good luck
szicsu
Hello Szicsu,
Thank you very much for the OIDs.
Amit
182
