Aironet WAP goes down often
Iam facing an issue with Aironet WAP's. Some of the WAP are going down often. This WAP are powered on with power injectors. As a workaround once after remove and reconnect the patch cable from patch panel to the power injector WAP will come up.
appreciate your help to find the root cause
Thanks in advance
Shanil
Re: Aironet WAP goes down often
When you say it goes down, does that mean you can't associate and pass traffic, or that it powers down?
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yes.. i cant associate and pass traffic, but i can see the WAP from sh cdp neighbours from the switch, but not able to ping or access the WAP
Hall of Fame Super Gold
Do the WAP reboot?
Once after reboot the WAP i would be able to access the WAP ,associate and passtraffic.
While WAP is down its powered on and iam able to console and could see all the radio interfaces are up, there are some logs for AAA radius server authentication failed ,find below
*Mar  8 02:34:50.211: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:35:27.188: %RADIUS-6-SERVERALIVE: Group rad_eap: Radius server 192.168.200.14:1645,1646 is responding again (previously dead).
*Mar  8 02:35:27.188: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.200.14:1645,1646 is being marked alive.
*Mar  8 02:35:38.070: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.200.14:1645,1646 is not responding.
*Mar  8 02:36:13.156: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.10.9:1645,1646 is being marked alive.
*Mar  8 02:36:28.280: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.10.9:1645,1646 is not responding.
*Mar  8 02:36:28.280: %RADIUS-3-ALLDEADSERVER: Group rad_eap: No active radius servers found. Id 229.
*Mar  8 02:38:51.951: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:43:11.941: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:46:20.526: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:49:51.234: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:50:52.514: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:53:57.464: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:55:02.261: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:56:06.147: %DOT11-4-MAXRETRIES: Packet to client 0021.6a0b.b80e reached max retries, removing the client
*Mar  8 02:56:06.147: Client 0021.6a0b.b80e failed: reached maximum retries
*Mar  8 02:57:17.949: %DOT11-7-AUTH_FAILED: Station 0021.6a0b.b80e Authentication failed
*Mar  8 02:58:23.966: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 02:59:01.895: %DOT11-7-AUTH_FAILED: Station 0021.6a0b.b80e Authentication failed
*Mar  8 02:59:25.280: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:00:02.177: Client 0021.6a0b.b80e failed: reached maximum retries
*Mar  8 03:00:02.184: %DOT11-4-MAXRETRIES: Packet to client 0021.6a0b.b80e reached max retries, removing the client
*Mar  8 03:05:13.237: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:05:38.016: %RADIUS-6-SERVERALIVE: Group rad_eap: Radius server 192.168.200.14:1645,1646 is responding again (previously dead).
*Mar  8 03:05:38.016: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.200.14:1645,1646 is being marked alive.
*Mar  8 03:05:50.177: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.200.14:1645,1646 is not responding.
*Mar  8 03:06:02.369: %RADIUS-3-ALLDEADSERVER: Group rad_eap: No active radius servers found. Id 45.
*Mar  8 03:06:14.542: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:06:28.279: %RADIUS-6-SERVERALIVE: Group rad_eap: Radius server 192.168.10.9:1645,1646 is responding again (previously dead).
*Mar  8 03:06:28.279: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.10.9:1645,1646 is being marked alive.
*Mar  8 03:06:47.921: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.10.9:1645,1646 is not responding.
*Mar  8 03:07:06.082: %RADIUS-3-ALLDEADSERVER: Group rad_eap: No active radius servers found. Id 47.
*Mar  8 03:08:26.030: %DOT11-7-AUTH_FAILED: Station 0021.6a0b.b80e Authentication failed
*Mar  8 03:09:00.571: %DOT11-7-AUTH_FAILED: Station 0021.6a36.f204 Authentication failed
*Mar  8 03:09:48.183: Client 0021.6a0b.b80e failed: reached maximum retries
*Mar  8 03:10:44.963: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:11:44.490: %DOT11-7-AUTH_FAILED: Station 0026.bbb1.e195 Authentication failed
*Mar  8 03:14:06.304: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:15:11.103: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:18:17.630: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:19:18.911: %DOT11-7-AUTH_FAILED: Station 40fc.8947.0777 Authentication failed
*Mar  8 03:20:32.489: %DOT11-7-AUTH_FAILED: Station 0021.6a0b.b80e Authentication failed
ENOCH3F1A_WAP003#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       172.20.1.20     YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.23             unassigned      YES unset  up                    up
Dot11Radio0.55             unassigned      YES unset  up                    up
FastEthernet0              unassigned      YES NVRAM  up                    up
FastEthernet0.23           unassigned      YES unset  up                    up
FastEthernet0.50           unassigned      YES unset  up                    up
FastEthernet0.55           unassigned      YES unset  up                    up
ENOCH3F1A_WAP003#
ENOCH3F1A_WAP003#sh dot11 as
802.11 Client Stations on Dot11Radio0:
SSID [WAP] :
MAC Address    IP address      Device        Name            Parent         State
183d.a214.3818 0.0.0.0         ccx-client    ENOCH3F1A_WAP00 self           AAA_Auth
40fc.8947.0777 0.0.0.0         unknown       -               self           AAA_Auth
a088.b420.1c34 0.0.0.0         ccx-client    ENOCH3F1A_WAP00 self           AAA_Auth
ENOCH3F1A_WAP003#
Hall of Fame Super Silver
Well as far as associating to the ap, the logs is telling you that connectivity has been lost on the AP to radius. Have you tried moving the ap to another switchport or replacing the patch cord to see if you can isolate the issue. Can you ping from the ap to the switch?
Scott Fella
Sent from my iPhone
-Scott
I tried changing the uplink and cable to different switch port still it happened ,and please note that we are facing issue with multiple WAP's(thats why hopes should not be cable issue). Iam not able to ping the switch from AP, also switch is not showing from AP sh cdp neighbour. but from AP i can see the switch.
As from the logs if radius server is not reaching and thats the issue then still i would be able reach the WAP through management ip right?
Remove your radius stuff and try again
As scott pointed out this doesnt appear to be an issue with your AP going up and down, rather an issue with the radius server or connection to the radius servers.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
HI
I tried remove the AAA Radius from WAP ,still iam not able to reach the WAP.
How?  Try the command "no aaa commun".
Even if this would cannot be a resolution as iam using radius for wireless user authentication still i tried removing radius by "no aaa new-model" still iam not able to reach the wap.
What is the error message when you try to connect to the WAP?
Do you have ACL on the WAP?
Did you enable remote login using local username/password?
Below is the error message iam getting from the WAP while iam trying to connect the client.  iam getting the signal but clients are not associating to the WAP.
*Mar 12 05:10:52.853: Client 0021.6a0b.b80e failed: reached maximum retries
*Mar 12 05:11:30.541: %DOT11-7-AUTH_FAILED: Station 40a6.d97d.7239 Authentication failed
*Mar 12 05:13:01.230: %DOT11-7-AUTH_FAILED: Station 001e.6567.9174 Authentication failed
There is no access-list configured, and SSH remote login to the device is configured while radius server is unavailable. users are authenticating with radius EAP authentication with Active Directory.
Wait a sec ... This is not right.
The error message you posted above means that the client is failing to associate/authenticate to the WAP because the username/password is incorrect.
Can you please try to use OPEN authentication?
II tried still im not able to ping the AP,also association not working
I rebooted the wap everthing is working fine now.now im capturing logs through syslog,lets review the logs next time WAP will fail
1204
