All clients drop association at the same time
muthumohan
We are seeing clients dropping their association with few APs all at the same time and would not connect back for several minutes (or even hours). And all of a sudden, they are start to connect back normally.
Wondering what can cause these kind of frequent client disconnects? Only a section of the building is affected and the remaining areas are fine.
Also, at times, I see the signal strength varies between Excellent and Poor within few seconds.
We are using LAPs and WiSM.
Any help would be appreiciated.
Thank you,
Mohan
Leo Laohoo
If it's affecting the same section of the building regularly then it sounds like you have a spectrum or radio interferance.
Check the logs of the WLC and AP (WLC command "sh ap eventlog ") to see if your WLAN is being subjected to DDoS or any errors.
Are you seeing this in the 2.4ghz and 5ghz? What have you observed or is this what users are telling you? Is it all the users or just certain users?
-Scott
Its in the 2.4 GHz band. I have observed this behavior. It works well for a day or two and suddenly a couple of APs only drop all the clients all at the same time. After few minutes (or hours) they are connect back to the APs fine.
This repeats 3 or 4 times in a week.
Mohan
