01-21-2014 11:22 AM - edited 07-05-2021 12:01 AM
Dear Folks ,
I have a setup with 5508 controller in Anchor - foreign setup .
My SSID is configured with webauth in foreign controller and is anchored to the anchor controller .
My client when disconects and reconnects he is redirected again to the login page .
I have checked the user idle timout and session time out where i have kept a larger value but the issue is not got resolved
I had did a debug of the client from bot anchor and the foreign , please find the logs attached
01-21-2014 01:21 PM
Can you post your show WLAN
What do you have the session timer and idle timer set to on your anchor?
01-21-2014 03:31 PM
7.5 introduces sleep client feature
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn75.html
Guest access clients that have had successful web authentication are allowed to sleep and wake up without having to go through another authentication process. You can configure the duration for which the sleeping clients are to be remembered for reauthentication. The valid range is 1 hour to 720 hours (30 days), with the default duration being 12 hours. You can configure the duration on a WLAN and on a user group policy that is mapped to the WLAN.
01-21-2014 06:59 PM
Hi saravanan.
Will I be able to configure sleeping client feature in anchor foreign setup . Where do I need to enable the sleeping client option .
Angus
Sent from Cisco Technical Support Android App
01-21-2014 07:09 PM
Sleeping clients work after the idle timer expires. You need to make sure that your configuration is correct. The session timer should always be higher than the idle timer. These have to be set on the anchor WLC. Idle timer I wouldn't go past 2-4 hours and only use sleeping clients if you don't want users to login after x number of hours (after idle timer expires) up to 30 days.
If clients still are being forced to login, then there is a configuration issue.
03-24-2015 06:07 PM
Hi Scott, I have a few questions around it.
So, am I supposed to enable sleeping client in WLANs on both foreign and anchor controllers? or just on the Anchor controller?
As to the session time-out for the sleeping clients, would it reset to the default or would stop elapsing when the client goes into sleeping? I could not find these information on Cisco.com at all.
is there any Cisco documents that explains requirement details of configuration between WLANs on Foreign and Anchor controllers? if you could share it with it. it would be great.
