06-30-2014 12:26 PM - edited 07-05-2021 01:08 AM
Evening All,
Currently chasing my tail with a newly installed Anchor WLC. Foreign WLC's are running 7.0.240.0 (mix of WiSM1's and 4404's) and the Anchor is a 2504 running 7.4.110.1. We have both the control and data paths up between foreign and anchor controllers but clients are not getting an IP address from the anchor controller.
On the guest interface configured on the anchor the primary dhcp server ip address is set to the management IP and we've confirmed that dhcp proxy is enabled.
We've also been through the guest WLAN config with a fine toothcomb and can confirm that all settings are the same. The anchor is sat behind an ASA.
Where are we going wrong
TIA
07-01-2014 11:39 PM
Please attach the debug logs (debug client mac) in the anchor and foreign WLC, that would help us resolving the issue and also please add the config of the WLCs.
07-02-2014 08:14 AM
If you could also post the output of a show running-config no-ap, that would help as well.
