antenna for 1231
Original bought AIR-ANT4941 and 1200 to replace 1100 for better coverage. It appears the 4941 antenna is eqaul to intergrated antenna of 1100. What antenna is the next step up for indoor use to increase coverage
Silver
Re: antenna for 1231
Hi James
Here you are the Cisco Aironet Antenna Reference Guide:
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a008008883b.html
It looks like you shoud use AIR-ANT1728:
"Ceiling-mount indoor antenna with RP-TNC connector-This antenna was designed for WLAN applications with frequencies of 2400-2500 MHz. The antenna is omni directional and has a nominal gain of 5.2 dBi. It comes with a clip that allows it to be mounted to a drop-ceiling cross member"
Here you are more info on this antenna:
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a0080286064.html
Thank you! I was pretty sure that was the one, but I wanted to make sure.
197
