Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Antenna for AP1200
Is it possible to uses an external outdoor antenna (typically used for a bridge) such as air-ant24120 with the 1200 series access points
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Antenna for AP1200
Hi Tanveer,
It is possible to use the 24120 Antenna with the 1200 series AP's. Have a look at the attached docs;
AIR-ANT24120
This antenna operates in the 2400-2500 MHz band and is designed for use outdoors. The antenna is compatible with Cisco Aironet radio products utilizing a reverse-polarity threaded naval connector (RP-TNC) connector.
This antenna is designed for use with Cisco Aironet access points and bridges but can be used with any 2.4-GHz Cisco Aironet radio device that uses a reverse-polarity threaded naval connector (RP-TNC).
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a0080148acf.html
Omnidirectional Mast mount outdoor high gain antenna with a RP-TNC connector-This antenna was designed for WLAN applications for frequencies of 2400-2500 MHz. The antenna is omni directional and has a nominal gain of 12 dBi. This design uses an elevated center-feed to produce an elevation pattern with very little "squint" or beam-tilt. It is designed to be mounted on a round mast.
Cisco Aironet 1200 Series
Cisco Aironet Antenna Reference Guide
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet09186a008008883b.html
Hope this helps!
Rob
Please remember to rate helpful posts.........
1 REPLY
Hi Tanveer,
AIR-ANT24120
From this doc;
From this doc;
Hope this helps!
Rob
145
