06-05-2009 09:55 AM - edited 07-03-2021 05:41 PM
hi!
I want to run 802.11A for VoIP and 802.11G for data WLAN.
1. do I need a pair of antennas for 2.4g and another pair for 5g HZ? four of them?
2. does AP support dual-bands at the same time?
Solved! Go to Solution.
06-05-2009 10:25 AM
1) Yes. You need at least one for each band. Two is better for most implementations, for signal diversity.
2) Yes. There are two independent radios in the case, they operate with complete independence.
Good Luck
Scott
06-05-2009 10:25 AM
Good Luck
Scott
06-05-2009 05:42 PM
Cisco Aironet Antennas and Accessories Reference Guide
Cisco Aironet 2.4 GHz and 5 GHz Antennas and Accessories
Hope this helps.
06-08-2009 03:19 PM
Thanks for the rating.
