Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Any thorough documents on upgrading a set of 8500 series HA controllers with a large amount of AP's of various models?
I have completed the process but not without some hiccups. I had to piece together data from different documents. Basically, there is no information out there on what one can expect during the process and, as I mentioned in the topic, HA 8500 controllers with hundereds of AP's varying in model.
1 ACCEPTED SOLUTION
VIP Purple
HI,Here is the guidline :
HI,
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/High_Availability_DG.html#pgfId-46645
Dont forget to rate helpful posts
VIP Purple
HI,
This is the most thorough
This is the most thorough document I have seen. The documents for 7.4.121.0 code was not as clear. I wish the documentation would give an idea of how long you should expect the process to take given a certain number of access points. Also, I have not seen any documentation stating that the controller is only reachable by console (in my situation anyway) during the AP predownload process. I was not expecting to not have access to the controller via SSH & GUI for over an hour.
Thanks for your input!
56
