Anyone else using Tessco Dual Band MIMO Antennas ?
Specifically the M6025045MO13602 model show here for the 1252 AP ?
http://www.tessco.com/products/displayProductInfo.do?sku=301357&eventPage=1
Just curious if there are opinions.
1 REPLY
Hall of Fame Super Silver
Re: Anyone else using Tessco Dual Band MIMO Antennas ?
I have used this in some of my installs and they worked fine for me. Of course, make sure you survey with these if you plan on installing these later. I like these because they are compact in size. Also a lot cheaper...
Ask for Nathan if you want something customized for mounting purposes.
http://www.sparcotech.com/cgi-bin/commerce.cgi?preadd=action&key=SP-MIMO24586E-CM
-Scott
129
